Old 03-31-2007, 12:45 PM
Default Gobi Cargo Buckle Install Instructions
Hello all...
Does anyone happen to have the instructions for the installation of the Gobi Cargo Buckles?
I can't seem to find mine and I'm gonna need to install them today. I searched the Gobi site but they didn't have a .pdf for the cargo buckles.
I haven't looked to see what's involved in the install so it may be quite intuitive. However, the set did come with an extra bag of hardware so...
Thanks in advance!!
-Matt
06 - Black Caddy SRX
Old 03-31-2007, 02:07 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Default Re: Gobi Cargo Buckle Install Instructions
Here it tis:
http://www.gobiusa.com/GobiJerrySystem.pdf
It's very straight forward and won't take long. I think it took me about a half hour.
Old 03-31-2007, 03:52 PM
When you mount these, put them in a spot where they are easy to get to.
In other words, out them on the same side your ladder is on. Gas/ H2O cans are heavy when filled. You should have a angle bracket as well. Make sure to space it so it stays away from your light wires.
It's an easy install. You just need to have pipecleaner arms to get under those 2' brackets.
Old 04-01-2007, 11:59 PM
Thanks for the info fellas! I was able to get them installed w/out any problem. When I searched Gobi site, I glossed right over the link for the Jerry Can install, duh!
So thanks NJ! I took your advice as well Tim! No, I do not have pipe cleaners and needed some patience.
-Matt
