Old 04-07-2007, 05:12 PM
Default Re: gobi rack
Originally Posted by lotus4s
No problem with the install but the wind deflector does block my XM satellite signal sometimes when going south. The wind noise is pretty bad without the deflector so I live with it as I didn't feel like relocating the antenna.
Thanks Tim for the definitive answer....
Also, if you guys/ gals do have the XM interuption, it's an easy fix. All you need is a Sirius antena to be mounted either on top of the rack or all the way in the back. It's about the diameter of a golfball but is flat. It's very easy to integrate. I don;t have a writeup on this or anything, but you can always PM me your info and I can go through it with you. GOBI has the kits or can tell you exactly what you need and I how to do it as well.
