Old 04-25-2007, 09:49 PM
TouchdownTN TouchdownTN is offline
TouchdownTN is off the scale
Default AC not working?
I have an 03 H2 and my AC has stopped cooling. I know freon is no longer used but is there a gas that I can buy and charge the unit myself or something else that I might can do to fix this. I'm hoping I won't have to take the truck into the dealer as it is obviously out of warranty and my closest dealer which is an hour away is only open the same hours as my business. Any help or ideas is greatly appreciated!
Old 04-25-2007, 11:41 PM
Default Re: AC not working?
I suggest taking it to a service location that can service the AC; it does not have to be a dealer.
the system uses R134a refrigerant, but it just does not wear out, if it is low, it has leaked out. Adding more without fixing the leak will do you no good. THAT IS, if there is a leak.
There are other reasons it may not be operating such as a high/low side pressure switch broken, a compressor clutch that won't engage the compressor.
That's why, I would suggest you have someone who knows AC systems, look at the system. It may cost, but it will be less expensive in the long run, than throwing money at items that do not fix the problem.
