Old 05-03-2007, 01:08 PM
speednr1's Avatar
speednr1 speednr1 is offline
speednr1 is an unknown quantity at this point
Default where is the motion(pbrake) wire for nav?
does anyone know which wire is the navigation motion wire that makes the nav system only work while stopped?
Dennis
ANY SPELLING ERRORS ARE TYPOS, OR , THEY ARE DONE ON PURPOSE.
Old 05-04-2007, 05:15 PM
speednr1's Avatar
Default Re: where is the motion(pbrake) wire for nav?
no one has put a switch in there wire to allow functions of the nav while moving?
Dennis
Old 05-04-2007, 06:50 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Pin
Wire Color
Circuit No.
Function
A1
OG
1044
Class 2 Serial Data
A2
Not Used
A3
PU
493
Rear Seat Audio Enable Signal
A4-A7
Not Used
A8
TN
511
Left Front Low Level Audio Signal (+)
A9
D-GN
1947
Left Front Low Level Audio Signal (-)
A10
BK
1946
Right Rear Low Level Audio Signal (-)
A11
D-BU
546
Right Rear Low Level Audio Signal (+)
A12
BK/WH
1851
Ground
B1
OG
340
Battery Positive Voltage
B2
Not Used
B3
PK
314
Radio On Signal
B4-B5
Not Used
B6
GY/BK
2334
Radio Mute Signal
B7
Not Used
B8
BN
599
Left Rear Low Level Audio Signal (+)
B9
D-GN/WH
1547
Left Rear Low Level Audio Signal (-)
B10
OG/BK
1546
Right Front Low Level Audio Signal (-)
B11
L-GN
512
Right Front Low Level Audio Signal (+)
B12
Not Used
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1567514&evc=sm&pubid=1202&cell Id=46726&mspsdsubkey=5196#tab9-1567514">Radio C2
Connector Part Information
  • OEM: 12064799
  • Service: 15305996
  • Description: 12-Way F Micro-Pack 100 Series (BK)
Terminal Part Information
  • Pins: C, E, H - M
  • Terminal/Tray: 12146447/3
  • Core/Insulation Crimp: E/C
  • Release Tool/Test Probe: 12031876-1/J-35616-6 (BN)
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1567514&evc=sm&pubid=1202&cell Id=46726&mspsdsubkey=5196#oth10-1567514">Radio C2
Pin
Wire Color
Circuit No.
Function
A-B
Not Used
C
BARE
1573
Drain Wire (U2K)
D
Not Used
E
D-GN/WH
817
Vehicle Speed Signal
F-G
Not Used
H
D-GN/WH
368
Right Audio Signal (+) (U2K)
J
BN/WH
367
Left Audio Signal (+) (U2K)
K
BK/WH
372
Audio Common (U2K)
L
OG/BK
2061
Navigation Mono Audio Signal (-) (UE9)
M
PK/BK
2062
Navigation Mono Audio Signal (+) (UE9)
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1567514&evc=sm&pubid=1202&cell Id=46726&mspsdsubkey=5196#tab11-1567514">Radio C3 (UM8)
  • OEM: 6098-2714
  • Service: See Catalog
  • Description: 1-Way F Coaxial Connector (L-GN)
  • Terminal/Tray:See Terminal Repair Kit
  • Core/Insulation Crimp:See Terminal Repair Kit
  • Release Tool/Test Probe: See Terminal Repair Kit
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=1567514&evc=sm&pubid=1202&cell Id=46726&mspsdsubkey=5196#oth12-1567514">Radio C3 (UM8)
Pin
Wire Color
Circuit No.
Function
A
BK
Coax
Old 05-04-2007, 09:50 PM
speednr1's Avatar
E
D-GN/WH
817
I assume E is right next to F correct? I also assume this is the pin behind the nav system?
Dennis
Old 05-05-2007, 12:06 AM
HUMTECH's Avatar
E next to F, correct. Right behind radio/nav head. Wire color dark green and white.
Old 05-05-2007, 12:19 AM
I won't say disabling this signal will not allow the system to be changed while driving; however, on most of the newer Navs GM is using, the VSS is only used to help supplement the GPS signal (similar to aftermarket Nav systems). There is a good chance the serial data link is used to tell the Nav system not to allow all functions to work.
I would be curious if disabling the VSS does anything, but set a code. Good luck.
Old 05-05-2007, 01:14 AM
HUMTECH's Avatar
Ya I would be curious as to what it does as well. I think f5 may be right on the class 2 data from the BCM sending data but am not sure.
Old 05-05-2007, 12:00 PM
speednr1's Avatar
I will let you know, this is how I have done it in previous cars.
Dennis
