Old 06-27-2007, 02:47 AM
tomp's Avatar
tomp tomp is offline
Default Anyway to verify gear ratio on Ring & Pinion set?
How could I go about verifying the newly recieved Ring & Pinion sets I received off of ebay are 4.56:1? Is there a way to do this? Thanks
Old 06-27-2007, 03:00 AM
Tallowood_Air's Avatar
Tallowood_Air Tallowood_Air is offline
Tallowood_Air is on a distinguished road
Default Re: Anyway to verify gear ratio on Ring & Pinion set?
number of teeth on ring gear divided by number of teeth on pinion gear.
take that number and multiply it by your lack of a google toolbar.
is possibly stamped on ring and/or pinion.
2007 SUV LUX All-Terrain Blue
Polished Radix Magnacharger; 2.8" pulley; Tuned by HESCO; Custom 4L80E "Raptor" by PACT
GM 2500HD Efans on SPAL controler; K&N filter element; Dynatech Headers + Cats; Magnaflow cat-back
37" Kumho Road Venture MT KL71 on 24" ZINIK Mazotti
Pioneer AVIC-Z1 HDD navigation; 2 x 12" JL W6; Custom Box w/ Lights
Old 06-27-2007, 10:30 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Well all H-2's are stock with 4.10 gears so the ones you recieved are obviously lower ratio at 4.56. There is A ratio stamped on every ring gear and if the ones you recieved have 41 teeth on the crown gear and 9 teeth on the pinion gear its A 4.56:1 ratio
Old 06-27-2007, 10:38 AM
Ed G.'s Avatar
Ed G. Ed G. is offline
Ed G. is off the scale
Put your truck on a lift, mark a spot on your drive shaft, turn the rear wheels 1 revolution, count how many revolutions the drive shaft makes. Say it makes 4 1/2, you have approx. 4.50 gears.
2008 H3 Alpha - Boulder Gray
Old 06-28-2007, 03:39 AM
I think he wanted to check them Before he had them installed...
I mean, that's what I got out of his question
