07-04-2007, 02:37 AM
Tag Plate Brkt
Ok I have a 2005 H2 with the hard spare cover and where the tag goes it is a whole for the tag plate to sit in and the light above.
I want to use the spare cover to advertise. is there a brkt I can buy to move the tag to the left side around the bumper area and low enough not to hit the swing arm of the spare?
I seen one a few weeks ago but couldn't quite make out how it was attached.
thanks
07-04-2007, 04:43 AM
Re: Tag Plate Brkt
you can use a bracket from earlier h2s that had the plate holder and light attached to the drivers side tow hook or if you dont use your hitch much you can use a hitch mount plate holder like mine.
white 03 lux-gone
black 06 lux sut
07-04-2007, 07:38 AM
Re: Tag Plate Brkt
Nice, didyou make that, or did you buy it? Also it doesn't look as though it has the light attached to it. Does your state require having a tag light? Thanks...and nice looking truck by the way.....jamie
07-04-2007, 08:48 PM
Re: Tag Plate Brkt
white 03 lux-gone
black 06 lux sut
07-04-2007, 11:06 PM
Re: Tag Plate Brkt
how about like this?
07-07-2007, 05:19 AM
Re: Tag Plate Brkt
I think it was at the drivers side coming off the bracket.
where could I get one?
pne here or at a hummer store or is there an after market one I could get?
thanks
07-07-2007, 06:02 AM
Re: Tag Plate Brkt
Thanks a mil. That is kinda what I have been looking for. I'd like to show-off the rear spare instead of having the plastic thingy couver it up. I will get on ebay tonight and see if I can find one with the light. I believe its against the law to not have a lighted plate in Florida. Thanks again.....Jamie
07-07-2007, 06:04 AM
Re: Tag Plate Brkt
Is that some sort of TV reciever on the top of your rig? Just curious...Jamie
07-07-2007, 06:38 AM
Re: Tag Plate Brkt
I looked on ebay, and nothing. Do you have a company name or anything from where you got one with the light on it? Thanks....Jamie
07-08-2007, 01:53 AM
Re: Tag Plate Brkt
yes it is.....satellite....good eyes
07-08-2007, 03:39 AM
Re: Tag Plate Brkt
How would I incorporate that to work in the hitch...its just the plate frame? Also, how would I run the wires through the hitch? Thanks for doing research into this for me...I appreciate it....Jamie
07-08-2007, 03:42 AM
Re: Tag Plate Brkt
Also, how did you get the center cap on the spare? If it is the stock spare carrier, it has a protruding metal piece that extends out that has the light fixture on the end. Did you somehow cut it down, or what. I hate to start cutting, but if I have to ...oh well. I have a pic I can post up if you are unsure what I am talking about. Thanks again...Jamie
07-08-2007, 05:57 AM
Re: Tag Plate Brkt
 Thanks bro....Jamie
07-08-2007, 01:17 PM
Re: Tag Plate Brkt
Jamie i cut that metal piece off, if you look close you will see the backup camera in center of cap.
07-08-2007, 05:25 PM
Re: Tag Plate Brkt
You know...I thught that dot was a reflection of something in the fore ground. Very nice indeed, however I couldn't cut on my wheels, but being a stocker, wouldn't be an issue. Well, I guess I could always order another center cap from the manufactuer. Thanks man. Also, what did you use to cut that thing? It seems pretty freaking thick! Thanks bro....Jamie
07-08-2007, 11:58 PM
Re: Tag Plate Brkt
sharp hacksaw
07-09-2007, 06:30 AM
Re: Tag Plate Brkt
sharp hacksaw
Got some metal cutting Dremel bits tonight, hopefully it'll work.
