Old 08-05-2007, 03:04 PM
bonzaiii bonzaiii is offline
bonzaiii is on a distinguished road
Default Wiring help needed
I just installed the offroad light bar and I am adding some marker lights of my own to the light bar. For the rear marker lights I tapped into the tail light wires in the towing harness and for the front marker lights I have run a wire to the engine compartment but cannot find the tail light wire there, anyone have any suggestions on where exactly it might be ?
Old 08-05-2007, 04:54 PM
marin8703's Avatar
Default Re: Wiring help needed
dont know about the tail light wire. it may not come into the engine compartment, might go directly to the BCM located in the pasenger front kick panel.
wouldnt it be easier to use the front side marker lamps. if the wire is not tought enough to supply power to the lights you are addint you can use a relay and use that wire just to energizer the relay.
maybe someone will tell you for sure where the tail light wire goes. good luck, post pics when done.
