Old 09-12-2007, 05:26 AM
brad_p's Avatar
brad_p brad_p is offline
Default tire question
would a 37x 12.50 or a 37 x 13.50 rub on an h2 with a stock tourtion bar adjustment?
Old 09-12-2007, 06:01 AM
tower's Avatar
tower tower is offline
Default Re: tire question
Sometimes.
Old 09-13-2007, 02:15 AM
brad_p's Avatar
Old 09-13-2007, 02:28 AM
Hucky Hucky is offline
Brad
I dont know the answer to your question, Im gonna say yes it will rub--when turning left and right full turn
Try using the Search button, youll see it near the top of the page to the right of New Posts and type in similiar wording to what your looking for and you may see old posts that exist already.
Good Luck
Old 09-13-2007, 06:30 AM
tower's Avatar
What Hucky said. Also it does rub on some people's trucks and not others. You are right at the edge of what will rub with 37's without a lift. So for your truck, it's trial and error.
Old 09-13-2007, 07:16 PM
devilsfan's Avatar
Agreed. When my 37x12.5 were first put on my stock truck (Discount Tire), I had no tire rub whatsoever. When the dealer did an alignment, I had a rub while turning on the right front. So it's pretty sensitive.
Old 09-14-2007, 12:02 AM
mikejr's Avatar
mikejr mikejr is offline
i noticed on my 06 H2 at hard lock one of the sides would rub on the torsion bar ( i think thats the part it was rubbing on) and my truck was stock all the way around. It dependent upon many factors and even how you are situated on the terrain when turning the wheels....
2009 H2 Silver Ice LE
Old 09-14-2007, 06:54 PM
Talking Re: tire question
brad
i have 37x12.5 procomp extreme a/t's and they rub a bit on full turns only, they do seen to be a bit wider than the 12.5 listed on the tire.
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
Old 09-14-2007, 09:35 PM
brad_p's Avatar
do you think that they would rub with my stock tourtion keys cranked up, or would i need to buy some new ones.
