Old 09-30-2007, 04:46 AM
tomp's Avatar
tomp tomp is offline
Default Need pics of 2008 H2 radiator
Can anyone confirm if the 08s have electric fans? If so, can you please post some pics and measurements between the fan shroud mounting bolts etc?
Old 09-30-2007, 09:41 AM
tower's Avatar
tower tower is offline
Default Re: Need pics of 2008 H2 radiator
You have got to be kidding!!
Buy a fukking tape measure!!
Old 09-30-2007, 02:06 PM
mikejr's Avatar
mikejr mikejr is offline
I'll look and see, but from what i recall reading they do have the electric fans on them. I've only had the hood open on my 08 once since I bought it.
2009 H2 Silver Ice LE
Old 09-30-2007, 03:05 PM
tomp's Avatar
Thanks Mke! I am wanting to convert to electric fans on my 06. I drove through dealer lot looking and did not see any (looked for silver bumpers...Ha)
Old 09-30-2007, 09:45 PM
mikejr's Avatar
I believe I read somewhere that the radiator on the 08 was upgraded also, I know the grill was changed to get more air into the engine.
I might have read that in hummer brochure.
finally got done working around the house today and got cleaned up...off to the store now...we need provisions....should be able to get that pic tonite for you.
Old 10-04-2007, 01:12 AM
mikejr's Avatar
Hey Tomp.....
Havent forgotten about those pics. Got a guy on vacation and I've been out on the road all week looking at repo houses. I'll get you that pic as soon as i can buddy.
i'm tired....
Old 10-04-2007, 03:17 AM
tomp's Avatar
Hey, I know the feeling of being tired. Get them when you can
Thanks!
Old 10-14-2007, 11:28 PM
mikejr's Avatar
Tomp,
here are the pics of the rad and the fan set up. Its kinda tight in there so not sure how well the pics will show the set up. It appears to me that the dual electric fans are mounted on a large plastic shroud. There are three radiators in total.
Hope these pics help you out.
Old 10-16-2007, 01:49 AM
tomp's Avatar
Thank you Mike!
From those angles, it almost looks like the tranny cooler in front is a little larger as well. If you get time, please post some measurements of the little tranny cooler in the front.
Thanks again Mike for your efforts! Much appreciated!
Old 10-16-2007, 01:51 AM
mikejr's Avatar
Thank you Mike!
You are welcome. I'll get some dimensions on the front cooler for you. Hope those pics helped. Kinda hard to get any shots the way stuff is all jammed in there like it is.
Old 10-22-2007, 04:33 AM
tower's Avatar
Originally Posted by mikejr
Tomp,
This is highly unlikely. Probably a radiator, a tranny cooler and an oil cooler.
Old 10-23-2007, 11:12 PM
pteam's Avatar
pteam pteam is offline
pteam is on a distinguished road
What exactly do electric fans on the 08 h2s do compared to the regular fans on 03-07 h2's?
Do the electric fans run from the battery / electrical system which in turn is charged by the alternator / drive system, instead of running off just the drive system itself where when at idle it would spin very slow and not dissipate heat very good? Where the electric fans can run just as fast when at idle as compared to when driving? Give me a good tech explanation here. We have a 03 h2 limo for sale and are thinking about upgrading it to an 08 h2 in the spring.
Would the 08 electric fans make a big difference in AC capacity? AC is one of the biggest problems in a 25 passenger hummer limo.
Also the 6 speed tranny should overtime give better gas milage especially on highway , would it be worth it with GMID, compared to a leftover 07 with GMID?
My cars:
Lamborghini Murcielago
Supercharged Viper 800 HP Special Edition #49 of 50
Porsche Boxster S
My Hummers:
08 H2, 22 in rims, 6 HID lights, 20 in TV with DVD
4 H2 limos 3 have lighted dance floors + ceilings, 1 has Zebra interior 24-26 passengers
H2 Limo 26 pass lighted dance floor (sold)
H2 Limo 24 pass (sold)
03 H2 (sold)
H1 Open top (sold)
FirstClassLimos.net - H2 limos and party buses in OH & PA
my car collection
Old 01-28-2008, 02:20 AM
WEST OZ H2 WEST OZ H2 is offline
WEST OZ H2 is on a distinguished road
I'm in BOLD
[B]Ultimatly they give more HP, a standard fan sucks between 5 & 10 HP off the motor[/b]
Do the electric fans run from the battery / electrical system which in turn is charged by the alternator / drive system,Yes instead of running off just the drive system itself where when at idle it would spin very slow and not dissipate heat very good? This depends on wether the fan has a viscious coupling or if the fan is bolted straight to the motor, a viscious fan will cut in when the temp reaches a set point and cut out out at a low point, the fixed fan runs and pulls air all the timeWhere the electric fans can run just as fast when at idle as compared to when driving?This is correct Give me a good tech explanation here. We have a 03 h2 limo for sale and are thinking about upgrading it to an 08 h2 in the spring.
Would the 08 electric fans make a big difference in AC capacity?It makes no difference at all AC is one of the biggest problems in a 25 passenger hummer limo.For this issue your best bet is to mount another seperate A/C compressor and run two aircons. Here in Aussie it's what we do with the limo's
Also the 6 speed tranny should overtime give better gas milage especially on highway , would it be worth it with GMID, compared to a leftover 07 with GMID?Can't help with this one, don't even know what GMID stands for......
Hope this helps.
Al
Old 02-15-2008, 08:44 AM
sanfoja's Avatar
sanfoja sanfoja is offline
sanfoja is on a distinguished road
Originally Posted by WEST OZ H2
I'm in BOLD
Hope this helps.
Al
x2...I installed an electric fan conversion on my 5.7L Yukon and was the single most satisfying bolt-on mod I did. Instantly could tell I no longer had that power sucking mechanical fan attached. It does pull quite a bit of current though. I installed an underdrive pulley kit as well that came with an OVERdrive pulley for the alternator, just to keep the voltage up around 12 at idle. Comes on automatically with AC and has adjustable thermostat (sensor goes into radiator) to varying when fan kicks in otherwise. Been thinking about that for the H2 but still just thinking.
Joe Sanford
Huntsville, AL
2003 H2 Lux/Adventure, Burgundy, 37x12.5 MTRs on Matte Black Wheels, Smoked Cab/Running Lights, 07 Mirrors, Jet Stage 1 Chip, Volant CF CAI, AirRaid Intake Tube, Bi-Xenon HID, DRL mod w/diode, 2006 TNR, Matte Black Linex on Grilles & Front/Rear Bumpers, Ram Offroad Brush Guard, Rancho 9000 Remote Adj shocks, Rancho 5000 Strg Stab, FFD Ultra Extreme Electric Fans, Moog Pitman/Idler w/Cognito Support Kit, Kryptonite Tie Rods
Old 02-15-2008, 08:49 AM
sanfoja's Avatar
I'm in BOLD
Hope this helps.
Al
Also, GMID is.....quoted from another site.
There are three ?special? prices which are offered as fixed prices voluntarily by dealers. The dealers are paid a fixed profit by GM under these schemes and may or may not want to do it.
GM Supplier: available to all employees of eligible suppliers of GM. I know that Sun Microsystems and HP Compaq employees are eligible for that.
GMID: GM-In-the-Driveway program that are available to GM employees to offer to friends and family.
GMS: only available to GM employees.
GM Supplier and GMID prices are identical. GMS is significantly lower, below the quoted invoice price. Note also that the invoice price does not include the dealer holdback given back to the dealers, nor regional advertising fees that the dealers are required to pay.
Joe Sanford
Huntsville, AL
