Old 10-05-2007, 08:07 PM
BITURBOAMG BITURBOAMG is offline
BITURBOAMG is on a distinguished road
Default battery not charging?
I am having in issue with the dash saying battery not charging and the batt light on. I have changed the batt and alt and get the same issue? I have no clue what is going on but I have always had problems with the batt light, odo and radio staying on after I take the key out and open the door. I have to lock unlock the truck and open another door for it to turn off. Any info or tips would help. I have a clifford after market alarm and remote start. Can any well guide me on what I need to do? The truck came out of warranty 1k miles ago so I am trying to fix myself if I can.
Old 10-05-2007, 11:02 PM
pdsq99f4 pdsq99f4 is offline
Default Re: battery not charging?
Do your wipers work propperly? I've seen some weird things happen when the front wiper module takes a dump. Has the ignition switch been replaced recently? (could be clocked wrong). Pull the wiper fuse when it is acting up and see if it goes away.
Old 10-05-2007, 11:08 PM
IRA51's Avatar
IRA51 IRA51 is offline
did you install the after market alarm ? if you can take it to a good after market alarm shop that sells and installs that brand have them check it out . I have see many alarm installs that were the cause of many mysterious electric problems.
A government big enough to
you have.
-- Thomas Jefferson
Old 10-05-2007, 11:37 PM
the shop that did the work has been nothing but trouble. I have had it on this truck for three years. It took about 4-5 alarms before one would some what work. On the remote start any time you use it it says driver door ajar in the dash when you put the key in to go even though it is not open. I learned to live with that. I also have the magna charger but I dont think that is the problem. The problem started last week on a camping trip. The truck made a weird noise from the speaker in the drivers door then wouldnt start. We jumped it and figured the batt was old. Truck ran fine for another 300 miles/ 5 days or so then on my way home it said battery not charging but seemed fine. I though the batt was done and would just change it. Well on my way to change it the next day it had the same message but was freaking out that same noise was coming from the driver speaker and if I hit a window switch it got worse. I lost all power to dash, windows, brake lights etc. The truck drove for a few minutes and died in front of the batt place. I got a new batt and dropped it in and same thing it went dead. So we thought it had to be the alt and put that in and same exact problem. I ahev ripped the truck apart checking fuses etc and can not find the problem anywhere.
Old 10-05-2007, 11:58 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
if you dont have A field signal from the pcm the alt wont charge. PCM may be the fault
Old 10-06-2007, 12:31 AM
where do I check if the pcm is bad?
Old 10-06-2007, 12:52 AM
HUMTECH's Avatar
At the alt connector test gray wire with A voltmeter to ground key on engine not running, should be around 10v.
Old 10-07-2007, 12:46 AM
dkhummerh2's Avatar
dkhummerh2 dkhummerh2 is offline
dkhummerh2 is on a distinguished road
sounds like the shop is liable. i would make sure that they make it right.
dk
Darin Kaiser
Old 10-07-2007, 04:59 AM
HUMTECH's Avatar
If you get A shop to diagnose the problem and it turns out to be a bad remote start install that caused a failure then you have something to go on. Diagnose it yourself and they will basically tell ya to get bent. Either way good luck and if ya need any more info feel free to ask.
