Old 11-01-2007, 01:44 PM
audiofetish's Avatar
Default Re: 2000 H1 Question
2000 is a good year. TT4 does not have the best off road prowess if thats what your after, but that can be cured with a set of lockers. As far as the coolant goes, make the pressure test the system in front of you. Dont give them a heads up about it, just wander in there and tell them you want to see the system pressure tested, in front of you. If you give them a heads up they could do a quick fix to disguise a larger problem.
A couple of things it could be: Heater control valve, a very common problem. If they cant figure that one out, I would probably steer clear of that dealer just due to the simplicity of the problem.
Thermostats can cause leaks too, along with the housing. My truck is doing that a bit right now.
Hoses.
Heater core. This would be bad.
And finally it could be a cracked radiator mount, I've heard of a number of trucks having this problem over the years.
Out of curiosity, why does the dealer not fix this? Personally, I would be weary of any dealer that does not put a truck in to tip top mechanical condition before sale. Just my 0.02
ssgharkness,
Thanks for the response! That was some great info. I was wondering the same thing about the dealer not fixing the coolant leak. That was the only reason I was hesitating on the purchase. Well everything happens for a reason. I am going to keep my eye out for another one. Thanks again for your time!
09 Challenger R/T
95 Heep Wrangler
90 5.Slow
99 HMC4 Sold
01 HMCO Sold
04 H2 Adv Sold
03 H2 Lux Totaled
HOPE Volunteer
