11-30-2007, 01:13 AM
Vibrating Mirror Driver Side H3
Any tips on tightening up mirror. Tried adjusting torque screw no change. Or is it a recall thing on a 2006?
11-30-2007, 01:42 AM
Re: Vibrating Mirror Driver Side H3
Learn to shake your head at the same frequency that the mirror is at and the problem will disappear .
H2 REBEL lennyrebel
11-30-2007, 01:58 AM
Same thing happened with mine. It did seem to go away when I manully moved the mirror, but came back. Dealer did replace it but has come back. Learning to live with it.
11-30-2007, 08:07 PM
my passenger side view mirror vibrates, too.
it was the result of a little disagreement with a taxi driver who really wanted my mirror!
he would have succeeded had i not warned him of the pointed can of pepper spray i was about to release in his face!!!
what i have done is shim up the space between the top of the mount and the bottom of the mirror arm. you can anything like: those little rubber adhesive stickem's used for drawer stops or even a folded up match book!
it has reduced the movement of the mirro, but not eliminated when a high speed.
hope this helps!!!
11-30-2007, 08:24 PM
remove it and add innertube to reduce the firction if you are a DIY'ER
(with insurance)
11-30-2007, 10:28 PM
Mine has been vibrating, too, during higher speeds on the freeway. Only on the drivers side for me. I'm just living with it... don't want the dealer to mess it up more. Right now I'm going through a replacement of the front drive shaft which sprung a leak. The dealer is waiting on parts from GM. The good thing is that I have had an '08 H3 loaner for a week already.
12-01-2007, 01:32 AM
That's admirable, I on the other hand would be taking it back and they would be fixing it, till they got it right! AND, I'd also go trail test that loaner by getting some air in it too!
12-03-2007, 01:52 PM
Thanks for the feedback. Only been back to the stealership once for a recall since buying with a short list. Since they are bout 40 miles away. B4 I hit the home remedy's will add this to minor things to do b4 warrentee expiration
12-03-2007, 07:26 PM
I still have the driver side mirror vibrating, had it replaced, but it didn't fix the issue. Also have horrible wind noise from the A pillars, 3 times they were replaced, but the noise always comes back. Dew Hummer in St. Petersburg is worthless!  Last 3 times i've been in for service, they have not fixed 1 single issue that i had.
12-04-2007, 03:21 AM
Real trucks shake and vibrate and make noise--that's what trucks do-it ain't your mamma's buick.
H2 REBEL lennyrebel
