Old 01-01-2008, 11:49 PM
LesC.'s Avatar
LesC. LesC. is offline
LesC. is on a distinguished road
Default Re: HELLLPPP....tire pressure monitors
Originally Posted by Mike E
Yea, somewhere mid-year with the 07 models they dropped the sensor in the spare. If your spare has a rubber valve stem then you do not have a sensor.
Also, make sure you use a plastic valve cap and not a metal one. The metal ones bond with the stem and when you try to remove the metal cap it twists off the stem with it and your buying yourself a new sensor. It sucks when that happens!
why would a metal valve stem cap bond to the valve stem ? I ask this because I DO have metal caps on my valve stems and I have not had a problem so far. Is this something that happens over a long period of time ?
2008 Black H3 Alpha, Lux Pkg, 33" MTZ's
Old 01-02-2008, 03:42 AM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
not sure. if you keep the metal caps just snug enough to stay on you should be ok. it appears that maybe the aluminum of the stem coorodes inside the metal cap and they form a "bond" and when you go to twist of the cap, the stem goes with it.
____________________________
Old 01-03-2008, 10:00 PM
6pack 6pack is offline
6pack is an unknown quantity at this point
Are the tps units the same from year to year? I have an 07, but have come across a set from an 06 H3. Will they work?
2007 H3 Lux/Adv 5 speed, Gibson Extreme Duals cat-back, K&N FIPK, PCMforless tune, SAW torsion bars, Samco Shackles, Fox Racing shocks, Trail Duty Bump Stops, 35" ProComp Xterrain tires w/Tactical Rims, Gobi Stealth Rack
Old 01-03-2008, 10:14 PM
Auggie Mathis Auggie Mathis is offline
Auggie Mathis is off the scale
They will work just fine.
Old 01-04-2008, 02:02 AM
Thanks!
