Old 01-08-2008, 11:34 PM
H3NCO's Avatar
H3NCO H3NCO is offline
H3NCO is on a distinguished road
Default Re: My H3 Rear window washer fluid
I know there was a bit of a learning curve with mine as well. If the level is below a certain point it will not feed the rear window washer fluid line. The front will still work as there is fluid in the reservoir. Top it off and all should be fine. If not, do as others suggested and check for a clogged line or other issue.
