Old 01-16-2008, 08:20 PM
porschett's Avatar
Default Need help running wires
Okay, so I need to run 4 wires from the engine compartment, through the firewall, and into the interior on the driver's side. Does anyone have an easy way to do this or am I stuck drilling?
TIA
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
Old 01-17-2008, 02:47 AM
vador99 vador99 is offline
vador99 is off the scale
Default Re: Need help running wires
I used the hand break wire hole under the truck for mine!
Old 01-17-2008, 12:57 PM
SnakeH2's Avatar
SnakeH2 SnakeH2 is offline
Yours has a hand brake?
Where's WiFey?
Old 01-17-2008, 01:10 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
There is a black rubber grommet on the firewall.....drivers side (up above the brake pedal, steering area), when I did my Amp/Sub hook up I pulled the grommet out, drilled it for an exact, tight fit around the wire, slipped the wire through and re-installed the grommet.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
