Old 07-04-2008, 04:27 PM
JustinOK's Avatar
JustinOK JustinOK is offline
JustinOK is on a distinguished road
Default Re: Heater Core (Oh Sh^t)
Originally Posted by Ground hawg
the only problem I had doing mine was removing the bolts from the bulkhead manifold. it's alluminum and the bolts are steel after 9 years they might not come out without breaking. so be prepaired to drill them out very carefully.
Blow torch baby. Heat the bolt head up and you should be able to remove normally. I did that for two on mine.
98 TD HMC4
