Old 01-26-2008, 01:16 AM
Yetti Yetti is offline
Default Re: Major Leakage...???
as for brake squeek, it can be loads of things. one of the things to look at is dust build up from the pads in the caliper slides. if the calipers get stuck it drags a pad and makes a squeel. if the hub bearings are going bad it will make a constant squeel that goes away when the brakes are applied. in most cases it rust build up in the pad itsself and it creates hard spots that sqeek when you applie the brakes. its just a matter of up grading to a better pad material.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
