Old 01-29-2008, 09:13 PM
spoolking spoolking is offline
spoolking is on a distinguished road
Default 22x12 rockstars
hey guys trying to find out if i can run 22x12 rockstars on stock ride height and what size tire should i use
Old 01-29-2008, 11:49 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
Default Re: 22x12 rockstars
Yes the wheels are no problem, you can run a 37x13.5 (or)12.5x22 tire and most likely will not have rub issues unless your on uneven ground at full lock. I am looking into doing a 22" wheel in spring and this is the info I have found thus far. If you go with a 35" tire you definately dont have to worry about rub issues and there will be little to no speedo error as I believe the stock tire size is something like 34.5"
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 01-30-2008, 04:06 AM
thanks does that mean i can do a 22x12 on a 35 /12.50 /22 mud tire and have no issues on stock height
Old 01-30-2008, 05:18 AM
MVR 155's Avatar
No problems whatsoever, depending on the tire you will be about 1/2 inch taller having little to no effect on speedo calibration (you might be traveling about 1-2 mph faster than your speedo indicates). With a 35" tire you also run about 0 risk in terms of any rubbing.
2013 Audi S4
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 01-30-2008, 06:04 PM
thanks for the info 325/50/22 is the same as 35 inch tire correct
Old 02-05-2008, 05:59 PM
professorhp's Avatar
professorhp professorhp is offline
professorhp is on a distinguished road
What's the offset on the Rockstars 22X12? I know the 24X12 is something like -44, which means they will stick out like a set of dog ball's without a lift or flares.
I myself want the 24X12, but at -44 and no lift, im thinking it might look less than desirable.
PHP
Old 02-05-2008, 07:22 PM
TXSUT's Avatar
TXSUT TXSUT is offline
A low-profile, 12.5 inch wide tire on a 12" wide wheel? You might want to consider installing curb feelers.
Old 02-06-2008, 12:26 AM
That truck will ride like a$$ too.
try some 18's...much better!!!!!!!!!!
