Old 02-18-2008, 04:01 AM
ryanh2 ryanh2 is offline
ryanh2 is off the scale
Default Rattle fix
I am sure some of you guys have the common door panel and other rattles. What have you done to try and fix them? I did a search and found some different ideas but would like to get them in one thread. Thanks and please don't tell me to turn up the radio.
Old 02-18-2008, 04:23 AM
MattRoberts123 MattRoberts123 is offline
MattRoberts123 is on a distinguished road
Default Re: Rattle fix
DYNAMAT.
Cost me about 500.00 and made the car SOOO much better!
Carless... riding the bus... Trying to decide on which 08 H2 to get
Old 02-18-2008, 06:23 AM
What did they dynamat? the doors or the door panel? Please let me know.
Old 02-18-2008, 07:24 AM
csxmoose's Avatar
csxmoose csxmoose is offline
csxmoose is on a distinguished road
Cool Re: Rattle fix
i think i might try using this stuff inside the doors to see if it will expand enough to stop the rattling...
what do ya think?
http://www.touch-n-foam.com/
2003 Hummer H2 Vortec 6000 6.0, Air Susp Fully Loaded Pimper.
1991 Toyota Pickup 22re 4x4 3" body 5" susp 35x12.50's 150watt KC's 2.5" pacesetter, rancho steer/stab.
Old 02-18-2008, 05:33 PM
rxdi's Avatar
rxdi rxdi is offline
rxdi is on a distinguished road
I use the spray armor all on all the places were the plastic pieces meet on the doors and inside panels. This lasts about 3-4 months before it needs to be done again. It takes away almost all the squeaks and creeks from the inside.
Old 02-18-2008, 10:18 PM
CONRAD II's Avatar
DYNAMAT as much as you can!!!!!! That will completely eliminate the "rattle" if done right.
66' VETTE STINGRAY
07' Z06
Old 02-19-2008, 05:16 PM
datapimp69's Avatar
datapimp69 datapimp69 is offline
datapimp69 is on a distinguished road
so has anyone figured out what it is caused by?
is it the door panel aginst the door?
is it the door panel clips in the holes?
what is it comming from?
Old 02-22-2008, 02:06 AM
phazer42 phazer42 is offline
phazer42 is on a distinguished road
ok... with BSR issues... first you need to see if its the panel against the door, or something inside the panel making the noise either to the panel or to the door... then you just nee to isolate it.... one good way is to use felt tape, foam tape or something like that.... if its a clip issue, which it could be, sometimes putting a tape called Ultra High Molecular Weight( (UHMW) tape over the hole and then putting the clips back in works well.... and no, UHMW tape isn't scotch tape, its actually a very very nice thing to use to make surfaces slick....
