Old 11-05-2003, 12:39 PM
Arizona Hummerboy's Avatar
Has anyone out there used a High Lift Jack on there H2 yet? If so were did you place the jack?
I bought the jack for off road use.
Old 11-05-2003, 01:21 PM
BKLYNH2's Avatar
BKLYNH2 BKLYNH2 is offline
I have one, because our company does construction work and has them for lifting things. I have not taken it with me wheeling and don't think I ever will. A) it is a heavy monstrosity B) I personally do not think the H2 has many good locations to use it on. C)A friend of mine who has a great deal of wheeling experience relayed a story to me about a friend of his that lost his eye due to the high lift popping away from the vehicle under weight as it got unstable. I can think of plenty of other ways to get out of most situations without the highlift and I think I'm going to keep it that way.
GO PENS
Old 11-05-2003, 02:14 PM
We used a hi-lift on Steve's H2 once. It actually worked quite well. The rock he was hi-centered was released when we got the weight off of it. It's a good piece of equipment to have. You just never know what you may need.
Old 11-05-2003, 02:24 PM
RockYoda RockYoda is offline
RockYoda is off the scale
As long as the high-lift does not lift on the body you can place it just about anywere it will fit. Just be careful and think ahead of what you are doing.
I have used the High-Lift jack way too-many times to count. I once had one slip off of a rock while the weight of the truck was on it. Scary to say the least but nobody got injured. I also saw one hit a friend in the temple and knocked him to the ground when the shear pin broke, but he was fine after the birds stopped singing. They are dangerous (especially if you don't lube them well), but indispensiable to say the least. I recommend everyone on the trails to have one. Even if you use it once it will pay for it self.
Old 11-05-2003, 11:17 PM
Centerfire is off the scale
I suppose it would be too much to have on star send AAA out into the Moab?
Mike
Old 11-05-2003, 11:48 PM
Not only is the Hi-Lift a great jack, but it can be rigged up to be used as a winch. It is a definite must have when off-roading.
Old 11-06-2003, 02:08 AM
Steve R Steve R is offline
Steve R is off the scale
Wow....the profanity filter must be working, check out DRTYFN's response!?!?!
Old 11-06-2003, 02:10 AM
I think you logged in under his name and made the post. You are so powerful Steve.
Disco vs. Hummer
Muwahahahahahahahah
