Old 06-26-2008, 02:07 PM
Default Re: Can the 06/07 realistically be made to a 7 seater?
in all the hummers, excluding 08, that i have seen, modification is required to have more than one seat in the third row....the benches are mostly designed with only 2 seatbelts....some fold flat forward, some slide back and forth and some fold flat backward (like a mini bed)....but all h2's from the factory only have the mounting hardware on one side (passenger)...if you found a bench that did not require any mods for install it would mean the side behind the driver woiuld not be attached to anything....
