Old 05-01-2008, 03:50 AM
HumminNBoatin''s Avatar
Default Front End Problems
Ok Guys I need Help
Problem:
Slight shimmy in my steering wheel from 50mph on up. Along with that I feel like I have a tire out of balance or a huge rock stuck in my tire as I get a hammering that I can feel in the floor of my truck when over 50mph. The Hammering and Shimmy occur with every rotation.
When backing out of a parking spot and turning the wheel I get a single Pop/Clunk Sound as well.
Truck Status:
71K Miles on it.
18 Inch Wheels with 37 Inch BFG K/M's----Recently Balanced with DynaBeads
New Idler Arm
New Passenger Side Hub
I think the T-Bars are cranked--Done before I got it.
Also I have shook the front end down thinking maybe my drivers hub was bad but it is showing no signs. Ball Joints and Tie rods are all good.
My guess:
I was thinking steering shaft but that would not give me a shimmy/Hammering with every rotation of the wheel. So I am leaning toward a bad CV Shaft? No quiet sure. Maybe Humtech would know? Any help would be great guys.
Thanks,
Eric
Old 05-01-2008, 08:32 AM
Yetti Yetti is offline
Default Re: Front End Problems
sounds like a bad CV joint in the front. if its a "cachunk cachunk" type sound while backing with the wheels turned then I would say most likely. if its the same going each way then it could be a wheel bearing. do you have times where your brake pedal is low? that would mean its a bad bearing and opening up the caliper.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 05-01-2008, 02:02 PM
Yetti,
Thanks for the response. I have no brake broblems at all. I Olny get a single clunk when I turn the wheel.
