Old 05-07-2008, 03:33 AM
NoMoGMPG's Avatar
NoMoGMPG NoMoGMPG is offline
Default Re: Centramatic Tire Balancers
Originally Posted by ROX
Then how come it shakes goin down the hiway?
Lordy! I got lots to learn about which stuff goes with an Alpha and which stuff doesn't.
You just went wheelin', my guess is you lost a couple wheel weights (its happened to me). Have your tires balanced.
The Alpha has everything that owners of earlier models wish they had. Powerful quiet diesel engine, 5 speed Allison 1000 trans with braking capabilty, front and rear e-lockers, a lower crawl ratio, a 2" lift kit...FACTORY!, 12K brakes and axles, 2 piece aluminum 17" beadlock wheels, better steering system, and A/C that actually works well. Honestly, the only thing you can do to improve the offroad capabilty is a 40" tire and maybe some rim guards.
'nuff said.
