Old 01-01-2006, 05:22 AM
Haiz Haiz is offline
Haiz is off the scale
Does anyone know how to tell if you radio is xm ready, i found this kit at this web site and I dont want to spend the money if my radio is not xm ready, http://www.jpcustoms.com/store/customer/product.php?pro...17044&cat=676&page=1
I have the monsoon stero with the 6 disc cd changer
superior blue, luxury package, adventure package, chrome side steps, sunroof, headrest dvd system mudflaps and soon to be xm radio
Old 01-01-2006, 06:19 AM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
Press the button labeled band on your radio and see if the xm tuner comes up. I'm alomst positive you have XM from your description, you just need to call XM and sign up.
____________________________
Old 01-01-2006, 10:00 AM
DarthKarl's Avatar
DarthKarl is off the scale
Each OEM radio in the H3 is XM ready, the question is whether an XM receiver is actually installed (like the one in your link) in your rig. Do what Mike E suggests to find out.
Old 01-01-2006, 03:26 PM
Do as Mike E suggests; however, you should have three months free and the salesman should have set it up for you.
Old 01-02-2006, 03:16 AM
I tried the band button, 2 fm's and one am, no xm, looks like i'll be ordering the kit. just wanted to make sure the factory radio is xm ready. thanks for the info.
Old 01-04-2006, 12:30 AM
kodiakz kodiakz is offline
kodiakz is off the scale
Your radio is definitely xm ready and the Terk GM direct kit works great for that application!
Old 01-05-2006, 09:08 PM
Roughwater Roughwater is offline
Roughwater is off the scale
I'm looking at installing XM in my H3 but not the kit above, I will be using one of XM's receivers. Have any of you done this and how/where did you mount the antenna?
Thanks-
NEW
2008 H3 - Boulder Grey - Adventure
OLD
2006 H3 - Slate Blue - Adventure
Old 01-05-2006, 09:16 PM
Aqualight Aqualight is offline
Aqualight is off the scale
I saw one at the dealer that had the antenna mounted on the dash on the passenger side. It was in the corner where the windshield meets the A pillar. Looked like it was stuck on with double sided tape.
Old 01-06-2006, 02:16 AM
I will be installing xm radio this weekend, using the kit listed above from jpcustoms, what's the best place to mount the antenna. where is the antenna mounted on the H3's with factory XM radio?
Old 01-06-2006, 03:03 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">I saw one at the dealer that had the antenna mounted on the dash on the passenger side. It was in the corner where the windshield meets the A pillar </div></BLOCKQUOTE>
Bad idea!! We learned this the hard way by re-doing many such installations as the customers had constant drop outs. Mount it on the roof and come in the rear hatch grommit.
Old 01-06-2006, 08:52 AM
I agree with Kodiakz. mount the antenna outside. I tried that on my C5 Vette, and it didn't work correctly, and the Vette had a large swept back windshield. The antenna must have sight with one of the two satellites to operate, and when mounted in a windshield the roof will block it when driving in some direction. (Unless you are in an urban area that is covered by ground repeaters.)
Has anyone considered using the standard XM/Onstar anetenna from GM. If you have Onstar and no XM, just replace the GM antenna with a version that has both coax leads.
Old 01-06-2006, 11:46 PM
where can you get the standard XM/Onstar antenna?
Old 01-08-2006, 02:10 AM
I got the gm direct kit installed, the radio recognizes the XM. It shows XM 1 and XM 2, but i keep getting a no signal reading, I've tried moving the antenna, but it still says no signal, any other suggestions.
Old 01-08-2006, 02:28 AM
Where did you mount the antenna? If you unplug the antenna, does it display "antenna error" or "antenna not detected"? Make sure you did not cut or crimp the antenna wire anywhere.
Old 01-08-2006, 02:37 AM
The antenna is mounted in the back, on the roof approx, 6 inches from the door. If I unplug the antenna wire it still says no signal.
Old 01-15-2006, 06:02 PM
does anyone the part number for the GM antenna that has both coax leads for onstar and XM?
Old 01-15-2006, 06:48 PM
Get another antenna, place it out on your hood (for test only) then plug it in and see what happens.
Old 01-15-2006, 07:18 PM
I already tried another antenna, still the same
