07-22-2008, 02:35 PM
Step tube vs/ Rocky Rail sliders
07-22-2008, 11:59 PM
Re: Step tube vs/ Rocky Rail sliders
 Looks good I would do the same but my wife is vertically challanged
Im going to Charlottesville Va in a couple weeks any local trails to run ?
07-23-2008, 12:55 AM
i would probably take the rock rails for a change if i got a new H3 only thing is i love the way the steps look for some reason...so i dont know purpose wise neither really do much for me, being i hardly ever step on it to get in, and as for the rock rails down here its all mudding so ive never been in a position where i needed rock rails....however it would be nice to not have to take off my steps everytime i go out....anyway LOOKS GOOD
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
07-23-2008, 05:21 PM
We're on the road far too much, so the decision to stay with 33's was based on MPG, so I wanted to increase the visual height of the truck, and to add some underbody protection for the few chance trips to the mountains.
Theres a bunch of really scenic dirt roads out that way, and a low key, but fun road/trail that heads to the upper parking lot for Crabtree Falls. If you go past the parking lot it winds thru the woods. The hike to the falls is 20-30min, be warned its downhill from the upper lot, so itll be uphill back to the truck!
http://www.crabtreefalls.com/directions.htm
The upper parking lot is on rt826 Meadows Lane
http://www.hikingupward.com/GWNF/CrabtreeFalls/
tnd2
06 Adventure - Flat black grill - Cognitos, Trail Duty +1/2" bump stops & a T-Bar crank - Rocky Road Rockrails - Doc's cold air kit,...
07-23-2008, 08:53 PM
tnd2 Thanks
07-24-2008, 12:21 AM
what type of rock rails you've got? they don't look like OEM's at that angle, or are they? I so far didn't get to the situation where rails would actually help against rocks or terrain, but by removing low hanging factory tube steps I gained enough clearance in order to prevent possibly getting stuck at several spots. There are generally easy trails in my area, with exception of few technical sections every once a while..with rails I feel more comfortable out there, less vulnerable.
07-24-2008, 06:37 PM
They are Rocky Road Rockrails, I had them LineX coated for protection from rocks being thrown up from the tires and give them some grip as steps.
http://www.rocky-road.com/H3rockrail.html
Really stout built, I had to tweak one of the mounting legs with a mallet but other than that, get help or use jack stands to help hold them in place while you put the bolts on. Less than an hour job.
tnd2
07-24-2008, 11:04 PM
I just installed them on my truck two weeks ago. Very well built, and good looking. The can be used as a step also (high step)
07-25-2008, 02:15 AM
those are a lot better looking then those factory steps, which make it a pain in the ass to get into a H3!
07-25-2008, 04:43 AM
yes, they looked to me a like rocky roads but they didn't look shiny..so you line-x'd them..that's why. I considered them too, but then I bought OEM's instead. I guess they're both good ones; I heard a lot good about rocky roads around this board..
07-27-2008, 01:57 AM
I have the rocky roads as well and they are just as strong as they look. I have put them to the test on several occasions.
