Old 08-08-2008, 02:02 PM
brad_p's Avatar
brad_p brad_p is offline
Default Grill swap pre to 08
There was a post a while back about putting 08 grills on older models. Someone said it fit just right but had minor brushguard issues or something. Can someone clear this up with me does it simply swap and is putting the brushguard an issue?
----------o-o-o-o-
[[_]|[]|[][___]
[---\-|-----[ -OIIIIIIIO-]
"(O) ) ---- (O) )/"H2"\) )
Old 08-09-2008, 05:52 PM
mrprimo's Avatar
mrprimo mrprimo is offline
mrprimo is on a distinguished road
Default Re: Grill swap pre to 08
The '08 grille switches out with no problems as long as you switch both the main grille and the lower black plastic grille portion. I had to cut a small section off the sides of the lower piece to allow room for the grille guard to mount but it can't be seen once mounted.
Old 08-12-2008, 01:56 AM
Hummer Guy's Avatar
Hummer Guy is off the scale
Without a brushguard it should fit just fine w/ no cutting.
-Brian
http://www.hummerguy.net
Old 08-13-2008, 02:29 PM
brad_p's Avatar
awsome, i like the brushguard.
----------o-o-o-o-
[[_]|[]|[][___]
