Old 09-05-2008, 05:08 AM
RCKSTR's Avatar
RCKSTR RCKSTR is offline
RCKSTR is on a distinguished road
Default Re: H2 Body lift (kit)
Originally Posted by gmonroe
Off the top of my head you will need to adjust your fan shroud, fuel filler hose, transmission cooling lines might disagree with it, steering shaft?, and sometimes automatic shifter linkeage. I am sure there are more, but that's what i remember from back in the day.
I figured the shroud would have to be moved, if not the whole rad.. The filler hose is simple with a piece of exhaust pipe of the correct diameter and hose clamps, the tranny lines should be run on the frame rail to the rad, wich wont move anyway if only the shroud is, steering shaft Im unsure of... and I believe the trans is shifted with a cable, a simple "tweak" of a bracket should fix that problem... But is there anyone who has actually done it??
_____________________________________________
2003 H2 w/ adventure package,4" Rancho lift, 20" cruiser alloys, Blacked out, 7" In dash DVD, Wood Kit, Billet chrome handles
