Old 10-14-2008, 06:16 PM
familyguy familyguy is offline
familyguy is on a distinguished road
Default Changing Geared Hub fluid
Has any tried changing the geared hub oil WITHOUT removing the tires? If so, any advice you can share on removing the drain plug and catching the draining fluid in the restricted space between the bottom of the geared hub and the inside of the wheel? Thanks!!
Old 10-14-2008, 10:51 PM
ssgharkness020147's Avatar
Default Re: Changing Geared Hub fluid
I havent. I think to really be able to get at it you'll need the tire off.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 10-17-2008, 11:09 PM
JollyRoger JollyRoger is offline
JollyRoger is off the scale
You could theoretically do it without removing the wheels, but it would be dumb and more trouble than actually removing the wheel.
