Old 02-13-2009, 08:19 PM
jmsspratlin's Avatar
Default Tie-rod bushing replace
I was under the truck this AM changing the oil and noticed that the bushing on the tie-rod on the driver's side is busted and torn. I'm sure that it is due to the over-sized wheels and the stress they put on the steering. I was wondering if anyone has a step-by-step guide on switching this out? I'm not the best mechanic, but I can do minor repair stuff. Any help would be greatly appreciated.
Old 03-07-2009, 12:10 PM
Default Re: Tie-rod bushing replace
Thanks to the overwhelming response
Old 03-07-2009, 05:54 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
I can't help you with switching out a bushing, however it may be a good time to switch out to the Fab Tech tie rods.
This fabtech install guide may help you either way.
http://www.fabtechmotorsports.com/pd...on%20Sheet.pdf
Good Luck!
Old 03-08-2009, 12:20 PM
Good Luck!
Thank you
