Old 02-19-2009, 09:27 PM
Rob #4 Rob #4 is offline
Rob #4 is on a distinguished road
Default P0449 Code Help
I had the check engine light come on on my 2003 H3. The code came up P0449. It says it has something to do with the EVAP (Evaporative Emission System). Has anyone ever has this code come up?
Old 02-19-2009, 09:35 PM
H3slate's Avatar
H3slate H3slate is offline
Default Re: P0449 Code Help
2003??
H3's were first on showrooms floors in 05' as 06' models.
Not sure about the code either.
Old 02-19-2009, 09:41 PM
I'm sorry 2008 H3
Old 02-20-2009, 10:49 PM
It could mean a few things...
Gas cap is not on tight
Pinched vent line
Electrical problem in EVAP
Actual EVAP system problem
Check your rig then do a google search under the code and look for information to resolve. Good luck.
Old 02-20-2009, 11:52 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Evap vent solenoid control code. Supply voltage shorted to ground or open to the vent solenoid. Control circuit shorted to ground, voltage or open. If all those test good you need a evap vent solenoid.
Old 02-23-2009, 03:21 PM
pdsq99f4 pdsq99f4 is offline
Isn't it under warranty?
