03-13-2009, 10:39 PM
Tranny Flush
Is the Dextron III the only recommended trans fluid to replace the stock fluid? I have reached 33K and need to flush the old fluid.. Thanks in advance....Jamie
03-14-2009, 01:37 AM
Re: Tranny Flush
You could use syn ,mobil 1,or Redline,or Amsoil.
A government big enough to
you have.
-- Thomas Jefferson
03-14-2009, 02:32 AM
Re: Tranny Flush
Thought there was an issue that only Dex III was suitable?
03-14-2009, 02:35 AM
Re: Tranny Flush
I think they recommend changing the fluid at 50K in the H2 owners manual, but it's cheap insurance to change it earlier and I've done some serious towing! I had my '06 done at 38k at an AAMCO dealer in one hour for 220. They told me the flush is a dealer tip off and doesn't do anything - to just change the fluid.
Hummer, like nothing else
03-14-2009, 02:39 AM
Re: Tranny Flush
Isnt there a difference in dropping the pan and flushing while changing the filter? arent you suppose to do all three things? i used royal purple in my truck and if you really want insurance you need to do the "tranny cooler bypass" search it
03-14-2009, 03:07 AM
Re: Tranny Flush
GM discontinued the use of the Dex-III branding and recommends Dex-VI (6) as a replacement. The only full synthetic that meets this requirement is Redline and GM fluid. However, it was quite a while ago when I researched the companies and their Dex-VI specs so others may be on board now and have it too.
03-14-2009, 06:03 PM
Re: Tranny Flush
It is my belief that Maintenance Schedule provided by GM is just that a recommendation under normal use. I have been wheeling in deep sand and have brought my Transmission temperature to above 200 degrees. My experience tells me the trans fluid breaks down above 170 degrees so I would change it. The only reason It went up is because I didnt air down like I should have. I have always used the dealer just because I want GM coverage.
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
03-14-2009, 07:31 PM
Re: Tranny Flush
Valvoline is marketing a full syenthetic DEXVI that has the GM approved license markings on the container as well.
03-20-2009, 08:32 PM
Re: Tranny Flush
So what yall are saying is that dropping the pan and changing the filter and fluid is not enough? You have to have it flushed also? If this is true is it better to have it flushed first then replace the filter and fluid again? Also I was thinking about upgrading the servo if I was changing the filter anyways is there a big difference in the OEM corvette servo and the billet one? I mean its going to be in my trans who cares if its made from shiny billet no one is going to see it? Plus I'm allergic to Billet Chrome.
Josh
03-20-2009, 09:40 PM
Re: Tranny Flush
Any Ideas??? I kinda need to get this done this weekend. I have a long road trip next week and I have about 58k on the beast and want to service the trans,
03-21-2009, 04:29 AM
Re: Tranny Flush
You guys are no fukking help so I guess off it to the stealership I go
03-21-2009, 04:59 AM
Re: Tranny Flush
Stealers trans service does everything u need , just overpriced
03-22-2009, 01:50 AM
Re: Tranny Flush
Do they replace the filter also????
03-22-2009, 02:31 PM
Re: Tranny Flush
I believe they do not change the filter...I think the flush will purge the filter in place.
Hope it helps!
03-22-2009, 07:39 PM
Re: Tranny Flush
Sounds like a Sanfrancisco Vice team mission. "Operation Tranny Flush"
Lol
January 20, 2009, A Dark Day in American History. Tehee.
Sold. Miss u buddy.2006 SUV LE Demonguard and extras.
Looking
