Old 04-12-2009, 05:01 AM
ULTRAHummer ULTRAHummer is offline
ULTRAHummer is off the scale
Unhappy Transmission Slippage in AM
I have an 06 H2 with just over 50,000 miles. For the last week or so, I have noticed some slippage (hesitation upon normal acceleration after first stop sign) in the transmission in the morning, before the tranny warms up. However, today, it continued for about ten minutes. Has anyone else run into this issue?
Thanks in advance!
Old 04-13-2009, 08:06 PM
IRA51's Avatar
IRA51 IRA51 is offline
Default Re: Transmission Slippage in AM
did you check the fluid level ? if so drop the pan and see if your clutch's are ground up in the bottom of the pan. change the filter and flush the trans and put in new fluid . hope you get lucky and the trans is still good . are you still under warentee ?
A government big enough to
you have.
-- Thomas Jefferson
