Old 05-17-2009, 03:39 PM
FiremanJay's Avatar
FiremanJay FiremanJay is offline
FiremanJay is an unknown quantity at this point
Default Re: How to black out all signal cover, brake lights on the H2
it has been awhile since i removed mine. but if i recall you need to remove the plastic cover that runs across the floor from one side tothe other, also reome the little storage boxes on the top of each wheel well then you can pop off the side panels you might be able to reach the rear light harness from the opening of the boxes its a tight fit but that is what is keeping you from taking out the lights once you remove the screws from the lenses
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
Old 05-17-2009, 03:41 PM
FiremanJay's Avatar
by sanding them down you get a cleaner job i actually sanded mine down to where all the writing was off then applied a total of 3 coats per lens and a coat of clear i used 1000 grit in between each coat and i thunk i used 600 grit for the initial sanding it has been close to 4 years now since i did it.
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
