Old 09-04-2003, 05:27 PM
89vette 89vette is offline
89vette is off the scale
My H2 runs fine now on 87 Octane. I'm thinking of adding an exhaust, intake and a programmer for some more power. For some reason it seems my H2 dies when it shifts into second. Is this the torque management feature people speak of? Anyway, I'm not interested in doing any mods that will require 89 or 92 octane.
03 Sunset H2!
89 Vette
02 Escalade
03 Sunset H2!
89 Vette
02 Escalade
Old 09-04-2003, 11:52 PM
2slo4now 2slo4now is offline
2slo4now is off the scale
That lag is exactly what torque management is. It PCM quickly and greatly retards the ignition timing prior to a shift. This makes for a Lazy or soft shift. It greatly reduces the wear and tear on the transmission. This is great for keeping warranty expense down but stinks if you like firm shifts. A programmer can help but you might have to select high octane tuning to accomplish that. I would call the manufacturer directly to get that answer.
Dan from Alabama
Old 09-05-2003, 12:20 AM
BADRAP BADRAP is offline
BADRAP is off the scale
Well anything that you do outside of nothing will require you to upgrade in your fuel usage, but hey with a Vette and Escalade you should know that already.. I know if I had a vette I would run the great stuff in it, so not a big deal, just a bigger gas bill...
Old 09-05-2003, 03:26 AM
whipplecharged whipplecharged is offline
whipplecharged is off the scale
The torque management is what you fell. Dan is correct on that.
You can install an exhaust sys and programmer and increase your hp by 70 without changing your octane to mid or hi.
Old 09-05-2003, 01:43 PM
I know if I had a vette I would run the great stuff in it, so not a big deal, just a bigger gas bill...[/quote]
The Escalade runs just fine on 87. The Vette requires 93 becasue its not stock. I'll tell you about it real quick.
89 Vette 6 Speed Coupe
396 CID small block stroker forged crank, rods and pistons 11:1 compression.
AFR 195 CNC Competition ported heads.
Lingenfelter Super Ram intake heavily modified by me.
Custom enginered hydraulic roller cam.
1 3/4" long tube headers.
Custom Hi flow cats
Corsa Cat back.
I run a speed density ECM for engine management and do all my own chip burning. The car is an absolute screamer that has about 450HP and 530ft lbs of torque. It idles smooth, doesn't overheat and drives like a stocker at normal speeds, gets 25 mpg on the hiway but jump on it and hold on. It should run mid 11's but I never make it to the track yet. So she must run 93. But I'm not wanting to buy $2.00 per gallon gas for the sake of a litte extra power in the H2.
03 Sunset H2!
89 Vette
02 Escalade
[This message was edited by 89vette on 09-05-03 at 09:11 AM.]
Old 09-05-2003, 02:13 PM
You can install an exhaust sys and programmer and increase your hp by 70 without changing your octane to mid or hi.[/quote]
Do you think these claims are real? Can you recommend a good package?
03 Sunset H2!
89 Vette
02 Escalade
Old 09-06-2003, 01:07 AM
Those numbers are advertised numbers. I have NEVER seen dyno runs with those kind of gains.
Advertised gains for a kenny bell supercharger is around 90 hp. Some how all these numbers don't add up.
Dan from Alabama
Old 09-08-2003, 04:00 AM
Xtremeflow exhaust without cold air intake is 32 HP gain.
SMA exhaust is 28 HP gain.
Xtremeflow Power Flash is 30 HP increase
Predator Programmer is 20-30 HP gain.
These are all advertised gains. Do they make them up?
No I don't think so.
I know that the numbers Xtremeflow came up with where actual dyno number.
How much HP are you making with your Radix kit?
Old 09-08-2003, 04:56 PM
Hey Whipplecharged
I have no way of knowing the gains. I have yet to find a 4wd dyno. Have you had any luck?
Dan from Alabama
