Old 09-11-2009, 07:59 PM
Lotusman333 Lotusman333 is offline
Lotusman333 is on a distinguished road
Default Driver Door Problem
Ok so I've been working on my H2 for a good while now, and I ran some wires through the hole that the wires for the driver door run through. Afterwards the unlock and window controls on the door along stopped working, however the mirror adjuster and selector work fine. I've taken the wires I ran out of the hole entirely, but the buttons on the door itself still do not work.
Also when I use the remote it only locks the other doors, and thinks that the driver door is open when its actually closed.
Can anyone give me a suggestion on what to do!? Thanks
Old 09-14-2009, 10:16 PM
[__--MUD--__]'s Avatar
Default Re: Driver Door Problem
There are 4 or 5 seperate plugs on the drivers side door switch. You can pry it up and out and make sure everything plugged in and fully seated.
Since you were running wires through the door, you might want to pop off the door panel anyway and yank out the speaker for a closer look... Possible rolling down the window could of snagged/broke a OEM wire on the way down.
