Old 11-07-2009, 11:12 PM
H2inMD H2inMD is offline
H2inMD is off the scale
Default Shift handle Set Screw Thread
Does anybody know what thread the set screw is that hold the shifter handle?
thanks
Old 11-07-2009, 11:58 PM
Easy Ed Easy Ed is offline
Default Re: Shift handle Set Screw Thread
On a 2003 model year that is a M6 X 1 X 10 Half Dog Point set screw with a T15 torx end.
Attachment 51750
Old 11-08-2009, 12:22 AM
thanks,
I dropped mine into the black hole, so it's off to home depot to get another one.
Old 11-08-2009, 12:44 AM
Good luck in your search. The T15 torx is not required, you can use a normal allen head set screw but you do need the half dog point type. You might have better luck at a regular hardware store (Ace, True Value or even a TSC for example) versus Home Depot, FYI
Ed
P.S. It could have fell all the way down (if you are real lucky) and if you pull the carpeted plastic console side panels away from the carpet you just may find it, again, if you are lucky.
