11-16-2009, 05:20 PM
Source for stainless steel brake lines?
Anybody got a good source for high-quality braided ss brake lines for the H2?
11-16-2009, 05:35 PM
Re: Source for stainless steel brake lines?
Just google it. Lots of makers
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
11-16-2009, 06:12 PM
I know, but I have also run into issues with other applications where the lines were not sized properly. I'd like someone with firsthand experience to give me a recommendation.
11-16-2009, 07:04 PM
i got crown performance brake lines.
belive me you cant go wrong.
you can order them thru trailduty.com
here is a link to a write up on them.
http://www.elcovaforums.com/forums/s...ad.php?t=30639
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
11-16-2009, 08:22 PM
Thanks! That's exactly the type of response I was hoping for.
Edit: I even posted in that thread.  LOL
07-21-2010, 12:08 AM
Ok, having some brake line issues now. Are you guys crimping down the clamp on the trail duty brake lines? I already wore a hole in my first set (on the right side only) and the second one installed seems to be doing the same. Talked to the manufacturer and they needed pictures etc. How did you guys solve this issue?
07-22-2010, 06:54 PM
yes crip down the clamps so the lines dont move thru the clamp.
just measure the same distance off the stock lines.
Fabtech Tie Rods
07-24-2010, 04:51 AM
I got my new lines from Phil at Trail Duty, best brake mod you can do. Would highly recommend them. I did them along with new rotors and pads. Huge stopping power difference!
Michael
___________________
2005 White H2 lux
2005 Dodge 1500 Hemi Crew Cab
2007 Tahoe (Flex Fuel)
07-24-2010, 05:02 AM
Tie wrap on each side of the clamp works fine for me
