Old 03-10-2010, 04:09 PM
eddiemcnally eddiemcnally is offline
eddiemcnally is on a distinguished road
Default OEM Brush guard
How do I install my oem brush guard? I also need hardward. Any suggestions and or help?
Thanx,
Eddie
Old 03-11-2010, 04:36 PM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
Default Re: OEM Brush guard
Well I just did mine not to long ago its very easy, did it alone. Pull the center black grill off, its held w/ 4 clips no bolts. Underneath you will see a place for the four bolts, dont remember the size 14mm maybe. Bolt it on the H2. The the black grill you took off you will have to trim away the plastice where it hits the brushgaurd. I used a Dremel.
I think total install was less than 30 minutes and I was moving like pond water in sub freezing temps.
If its the double there are two arms that go inside the grill opening. You have to remove the two bolts located on the H2 and get some longer one (about an inch os so) pick up two spacers about 3/4" to 1/2" to go in between.
