Old 04-02-2010, 09:27 PM
Hammer Hammer is offline
Hammer is off the scale
Post P0300 Random/Multiple Cylinder Misfire Detected
I´m on a long road trip far away from home (2000miles away) and hummer failed me today gave the p0300 code and started running reallly rough just all of a sudden when driving aroung 40mph. Any ideas.
Truck have 55000 miles...
Old 04-03-2010, 09:13 PM
Biskxp's Avatar
Biskxp Biskxp is offline
Biskxp is on a distinguished road
Default Re: P0300 Random/Multiple Cylinder Misfire Detected
had that issue when one of my cats was failing.
Old 04-04-2010, 04:32 AM
Hummeron37s's Avatar
Hummeron37s Hummeron37s is offline
Hummeron37s is on a distinguished road
same here had the code when my cat converter failed
Rancho 4" lift-Rancho Dual Shock-MC2 Rims-Mud Grapplers-Gobi roof rack-Piaa Offroad light-Piaa FU lights-10"TV-Brushguard-Gobi ladder-Taillight guards-Hi-Lift Jack-PC Swaybars-Custom stereo-Blacked out taillamps, blinkers, marker lights and Roof marker lights-Purple Cranium Spider-License plate mod-Magnaflow Hi-Flow Cats & Cat Back Exhaust-DRL Mod-Cb w/Dual Whips
Old 04-04-2010, 04:55 AM
HumminNBoatin''s Avatar
When my cats went I did not get that code. But mine did go out at almost the same mileage you have now. Typically when cats are going out you get O2 sensor codes. However if those guys had that code when cats went I would check there first. Then go pulling spark plugs and check if your cats are clear. If it is truly ignition i would replace plugs and cam/crank sensor.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 04-04-2010, 11:17 AM
Post Re: P0300 Random/Multiple Cylinder Misfire Detected
This happened after I had some deep snow fun moment earlier.
Goin to do just regular maintenance first hope it helps. Plug wires, Fuel filter, maybe plugs if thy look bad.
Old 04-05-2010, 03:05 AM
Xotik H3 Xotik H3 is offline
Xotik H3 is on a distinguished road
The problem will be common to all cylinders - cat, fuel filter, timing crank sensor... forget the plugs and wires.
