Old 05-20-2010, 01:40 AM
Default Re: Fabtech 6" Swap - Advice
STOP!!!
Before you make the swap, remember this.
In order to put the Fabtech kit on, you have to cut the lower part of the control arm brace and weld a block off plate.
Point is, you can take his kit off and install it on your truck but you can't make his stock again. (well, I guess you could make the cut and remove the piece that comes off yours and weld it back on his)
Mark
