07-07-2010, 11:14 PM
leaky pig
so we has some flooding here yesterday. the wife came to get me in the middle of a 3 mile run when it hit. (thankfully i think i might have drown lol)
anyhow when we were driving back home i noticed some water dripping in the truck around where the inside of both of the sun visors attach (little clip deal) and also a little where the front of the roof console is. im guessing the lights across the roof are leaking? well at least the center on is. i jumped up there and looked at it and it looks like it could be the culprit. anyone have any issues with this if so how did you fix it. its gonna be raining cats and dogs here the next week or so and i would like to get this fixed before her H smells as bad as my leaky ass K5. anythoughs?
thanks in advance
07-07-2010, 11:34 PM
Re: leaky pig
Could be the sunroof...if you have one. If not then do a search for "leaks" in this forum. Plenty of good info already posted. Requires removing the lights and using RTV sealant. Common H2 problem
2004 Black H2
07-08-2010, 12:15 AM
Re: leaky pig
no sunroof. will try the search function when i get to a comp and off my crackberry thanks
07-08-2010, 01:28 AM
Re: leaky pig
I had the same problem last year at first I tried using double sided tape. I ended up just using black silicone or gasket maker. Some advice, if one is leaking go ahead and fix them all, including the rear. Remove the old double sided foam tape and clean all contact areas real good before use the silicone.
07-08-2010, 02:13 AM
Re: leaky pig
Its the marker lights for sure, use silicone and problem solved, search the forum for more info tho.
2003 Black H2:
2006 Blue H2:
07-08-2010, 02:21 AM
Re: leaky pig
Anyone have advice on gettin the lights off? I saw one post about twisting them off? Not sure how to get them off. I will prob be doing it when I get off. Tonight. I've had one almost come off and I had to pop it back on. Hmmmm
07-08-2010, 03:11 PM
Re: leaky pig
On the right side of the light you can see a small notch in the bottom of the plastic. Use a flat head screwdriver and carefully push it into the notch, releasing the clip and gently pull up about an inch and then slide the light to the right.
07-09-2010, 01:40 AM
Re: leaky pig
Well I pulled them off gooped the crap outta them and slapped um back on. Pouring its a$$ off as no leaking. Wish I could say the same for the k5
07-09-2010, 05:24 AM
Re: leaky pig
had the same problem not to long ago... leaking in overhead console. i just checked all the marker lights and checked they were pushed in and no more leaking so far. hope you find the problem
07-11-2010, 01:14 AM
Re: leaky pig
so far so good. took them all off sealed the hell outta them and slapped them back on. no leaks so far. lets keep our fingers crossed. thanks for the help guys
