Old 08-22-2010, 04:59 AM
scottminor's Avatar
scottminor scottminor is offline
scottminor is on a distinguished road
Default 16.5" wheels
Is anyone running 16.5" wheels and military tires? Are there any issues with doing this?
2005 Hummer H2 LUX
Whipple SC
Ceramic coated headers
Old 08-22-2010, 06:41 PM
Scarsman's Avatar
Scarsman Scarsman is offline
Default Re: 16.5" wheels
I haven't seen any. I will say as a former tire guy, 16.5 tires come off the bead WAY easier than standard type tires. You really have to watch aired down situations. For example you can air a regular tire down to zero and drive it around and it will stay on the bead pretty well. With a 16.5 if you air it down all the way it will just come of the bead all by itself. Basically the only thing holding a 16.5 on the bead is the air inside.
Mirror caps - black bedliner
Old 08-22-2010, 06:49 PM
scottminor's Avatar
What about using the H1 wheels? They have bead locks on them right?
2005 Hummer H2 LUX
Whipple SC
Old 08-26-2010, 06:21 PM
Scarsman's Avatar
I am not sure, but I think they are. I am not sure how that would work. I do know that the genuine military style HMMWV wheels are REALLY heavy. We used to work on a couple from the local Guard unit at one of the shops I worked at. I have never handled any H1 wheels.
Old 08-26-2010, 06:40 PM
guruerror's Avatar
I remember reading somewhere that the H1 wheels are 'lug-centric' as apposed to the H2 wheels which are 'hub-centric.'
I think the H1 wheels have a larger cutout for the hub than the H2 wheels so they wouldn't be 'hub-centric' when you put them on an H2. I don't know if it makes a difference running lug-centric wheels on an H2 or not...but thought I'd through that out there as additional information.
CNTRY
DTOM
Old 08-26-2010, 08:08 PM
Scarsman's Avatar
Well, knowing that, you could have some vibration issues. That was a common problem when mounting non-hub centric wheels on a hub centric vehicle. They do make hub centric rings, which match the diameter of the wheel hub on the outside and the hub on the inside, and they help, but are not always perfect. Not sure if there would be any that would fit that application though.
Old 08-26-2010, 08:16 PM
guruerror's Avatar
Here's an article that describes the H1 rims a bit...
http://www.flashoffroad.com/features/Wheels/Wheels.htm
Looks like the H1's factory one-piece wheels are hub-centric too...but the hub is larger than the H2's so you'd need the ring to run them hub-centric on the H2.
The H1's two-piece wheels must be the ones that were lug-centric...
CNTRY
DTOM
