Old 09-08-2010, 10:27 PM
zmanH2's Avatar
zmanH2 zmanH2 is offline
zmanH2 is on a distinguished road
Arrow Oil Drain Plug
Does the oil drain plug/bolt have a washer? I have the 2006 model w/ only 20k miles. Recently, I noticed very minimal drops of oil on the garage floor coming from the plug. When I changed the oil, I noticed there was no washer there so I used a little teflon tape on the thread of the plug. After a couple of weeks, the leak is back again. The leak is very minimal at about one small drop every five days.
HUMMER Like nothing else.
Old 09-17-2010, 11:38 PM
zmanH2's Avatar
Default Re: Oil Drain Plug
Anybody?
Old 09-20-2010, 05:51 PM
VegasGuy's Avatar
VegasGuy VegasGuy is offline
VegasGuy is on a distinguished road
I have only changed the oil once, myself. I do not recall a washer being used. But then, I tend to not clutter my brain with details like that.
2005 H2 Desert Sand Lux with partial adventure package
Show me a H2 owner with low profile street tires and I will show you a guy who thinks the coolest way to shoot a Glock is cocked sideways.
Old 09-20-2010, 06:18 PM
zach.'s Avatar
zach. zach. is offline
zach. is on a distinguished road
The oil pan drain plug has a seal on it. Part number is 3536966
Old 09-21-2010, 12:58 AM
zmanH2's Avatar
Thank you! It will be a while before I'll replace the oil again though
Old 09-28-2010, 05:52 PM
finall finall is offline
Oil drain plug has a "built in" black rubber seal, that is part of the drain plug. It is not a separate piece.
You can put in the new one without draining the oil, if you are quick and use one hand to remove the old and the other hand to stick in the new and start tightening fast. Bit messy though.
Old 09-28-2010, 10:28 PM
zach.'s Avatar
[quote=finall]Oil drain plug has a "built in" black rubber seal, that is part of the drain plug. It is not a separate piece.
The seal does come with the drain plug. But the seal is also serviced seperately
2005 H2 Adventure SUV
Air Doc intake/ Airaid filter
BFG KM2 M/T 37x12.50x17
Cognito UCA kit, tie rods, shocks, sway bar links
GMPP exhaust
Gobi Ranger rack w/ spare tire mount
Rancho steering stabilizer
Warn brush guard mounted 4 lamp light bar
