10-18-2010, 10:44 PM
Battery not charging in Dash!
hi guys
i was riding normally in the streets and everything was ok no problems .. then the battery guage went down and got Battery not charging in dash ... i didnt stop the car and went back home, i parked it, and shut it off, now i cant run the engine.. the battery seems fine... remote key is working good while the car is off.. but i dont know where's the problem?
anyone can help?
2003 Pewter H2
- BFG's, Electric fans, Coil spring, Magnaflow Muffler, Xenon HID.
10-18-2010, 10:54 PM
Re: Battery not charging in Dash!
could it be a bad altenator? not charging the battery? if yes how to make sure its the altenator?
if the altenator died the car will not start right? i mean cant the car start with the battery only? or it will? cause when i try to start it i hear a voice and it cant start...
2003 Pewter H2
10-19-2010, 06:13 AM
If the alternator is bad it will still start and run as long as the battery has enough power to do so. But, without the alternator, the batter is like a fule tank, and will run out of power. Then you are dead right there.
If you can jump start it, then it is probably the alternator. If you have a volt meter you can test the output of the alternator with it running. It should be about 14 volts. I would try jumping it and see if that works. Or if you have a battery charger you could charge the battery and then see if it starts. If it does, then try unhooking the battery while it is running. If it dies then you know it is the alternator.
Mirror caps - black bedliner
10-19-2010, 02:42 PM
I would try to remove the battery and take it to a shop where it can be load tested. Sometimes batteries will show voltage of 12 volts but can not handle loads. Then it might be pratical to check other areas.
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
10-19-2010, 05:23 PM
Agreed, for testing the battery. You can;t check the battery with just a volt meter. It needs to be charged and then load tested.
10-19-2010, 06:10 PM
you can go to almost any auto parts store, and they will test the battery on the spot for you.
another thing, you can bypass the alt all together by running a cable from the battery directly to the starter. if it cranks the starter, should narrow it down. if it doesnt crank the starter, then....
10-19-2010, 08:35 PM
i got it fixed ...
problem was the alternator ... completley dead and sucked the battery while i was riding back home ...
bought new eom alternator and new battery but my battery guage on the dash went dead.. i think from removing the battery + and - ... anyway i have alot of broken guages hehe its not a problem cuz my fuel and temp guages are working  thanks guys for the help....
2003 Pewter H2
10-19-2010, 08:43 PM
i'm thinking of removing my xenon headlight kit ... does it effect the altenator?
2003 Pewter H2
10-20-2010, 05:46 PM
Well, only in that it draws power when they are on. If they draw a huge mount, then it can put extra strain on the alternator, but they are not likely to cause a problem.
10-20-2010, 06:07 PM
did you just put in a OEM altenator? or did you upgrade to a higher output one?
iirc the OEM one is only 145 amps
i like the mean green 220 amp alt, just dont like the $450 price tag
10-21-2010, 12:09 AM
Hi xenon hid lights draw less amps than a normal 9007 bulb by about 1 to 2 amps. So leave them in it has nothing to do with your X battery problem.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
