Old 12-04-2010, 02:32 AM
Rhyno's Avatar
Rhyno Rhyno is offline
Rhyno is off the scale
Default Installing air sensor links??
I have a Rancho lift with "Long" air ride sensor links that I'm going to replace with there "short" links. Can you guys give me step by step instructions on how to change out the links?
Here is a picture of the Long, Short, Factory links!
2006 Pacific Blue H2 SUT
-Rancho Lift
-39.5" IROK Tires
-20" Rockstar wheels
-MagnaCharger S/C
Old 12-05-2010, 07:33 PM
LEcustoms's Avatar
LEcustoms LEcustoms is offline
LEcustoms is off the scale
Default Re: Installing air sensor links??
http://www.gorancho.com/assets/instr...pdf/88556e.pdf
go to page 15
Good luck
"A clear conscience is usually the sign of a bad memory."
03 White H2
12 HID lights, factory lightbar, custom light bar for brush guard, OEM luggage rack, k&n intake, Gran MAF, 37" Toyo M/T's, 17x12 weld racing wheels, predator programer, Dynomax 4" catback exhaust,
02 10th Anniversary H1 #44 Will be missed
94 Custom pearl white H1(work in progress)
Too many mods to list
06 kawasaki stx-15f
02 yamaha superjet
02 polaris scrambler 500
Old 12-06-2010, 06:46 PM
Rhyno's Avatar
Thanks, I will try this today!
-Rancho Lift
-39.5" IROK Tires
-MagnaCharger S/C
Old 12-11-2010, 02:09 AM
Rhyno's Avatar
I installed the Rancho "short" links and my SUT was lowered just over 2".
With the long links I measured from the ground to the fender and my truck sat 50.5" at each corner. With the short links my truck sit's at 48" at each corner. I uncranked my torsion bars and my SUT rides very smooth now but I do need to get an alignment. I also rub when at full crank and would rub bad offroad! Hope this info helps you guys.
-Rancho Lift
-39.5" IROK Tires
-MagnaCharger S/C
Old 12-11-2010, 02:16 AM
Rhyno's Avatar
First pic is Rancho's LONG link
Second is Rancho's SHORT link
-Rancho Lift
-39.5" IROK Tires
-MagnaCharger S/C
