Old 02-18-2011, 12:49 AM
Dave92270's Avatar
Default roof cross bars install problem
hi guys,
I bought some OEM cross bars, got them assembled, but now I have problem how to slide them into the roof rails.
there are those plastic pieces on the roof rails end that seem to be removable so I could slide the bars in; but, how to remove those plastic pieces? they are at the front end of each rail. I don't want to break/crack them.
thanks for advice a lot!
Dave
EDIT: never mind, got it done already.
Old 02-20-2011, 01:35 AM
Camou2 Camou2 is offline
Camou2 is on a distinguished road
Default Re: roof cross bars install problem
You are at the wrong end of the rail. The cross members install from the rear. There is a removable assembly piece that has a single screw in it as I recall and once you remove the screw the metal piece that it holds down will come out. Then just slide in the cross rails.
www.thehummerclubinc.com
2004 H1 Softtop
2006 H2
2008 H3 Alpha
Old 02-26-2011, 08:31 PM
Dave92270's Avatar
thanks!
thats odd; on my '07 I had to remove the plastic in the front of the rail to slide them in, there is no removable piece at the rear of the rails.
anyway, got them installed OK. only wish they were more flush with the rails, but they hold fine...
Old 03-10-2011, 08:33 AM
cdmintmi's Avatar
cdmintmi cdmintmi is offline
cdmintmi is on a distinguished road
deffinately install from the front end of the rails. The plastic pieces have a little tab. Push in and pull whole piece out. peice of cake
Old 04-07-2011, 11:11 AM
anjy834u anjy834u is offline
anjy834u is on a distinguished road
if u find it more tricky then u can always consult a dealer, otherwise the mentioned steps above should do good to u.
