Old 04-09-2011, 04:10 PM
HummerJim's Avatar
Default My shifter is loose
All of a sudden there is a lot of play in my transmission shifter and you can see it twist at the base. If you hold it by the top on the driver's side there is 1" of play. Is this easy to fix?
Old 04-09-2011, 09:12 PM
Road Warrior H2's Avatar
Road Warrior H2 Road Warrior H2 is offline
Road Warrior H2 is on a distinguished road
Default Re: My shifter is loose
Is it possible that the setscrew on the shifter handle is loose?
It is on the side facing the dash and has to be loosened to remove the shifter handle.
If not you can loosen it with an allen wrench and take it off to lift up the shifter cover and drink holder to see if something is broke or came loose underneath.
It has been a while since I had mine apart to remember what I did but I know there are clips under the drink holder that hold it in place and there are wires that feed the 2 lights on the shifter indicator to show what gear it is in on the console.
Old 04-09-2011, 11:36 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
t15 torx bit on the set screw
1998 Chev Z71
2007 Chev Trailblazer SS
Old 04-10-2011, 01:23 AM
HummerJim's Avatar
Thank You both! That fixed it!!
