Old 04-27-2011, 09:57 PM
mack04 mack04 is offline
mack04 is on a distinguished road
Default Hummer H2 compressor programming update
Does anyone have the service bulletin number for H2 with A single stage compressor programming update?
Old 05-01-2011, 09:59 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Hummer H2 compressor programming update
#02-03-99-002: Service Air Suspension Message Diagnostic Trouble Code (DTC) C0711 and/or Clicking Noise From Rear of Vehicle with Ignition Off and/or Electronic Controlled Air Suspension (ECAS) Compressor Cycles Too - (Nov 26, 2002)
Subject:Service Air Suspension Message Diagnostic Trouble Code (DTC) C0711 and/or Clicking Noise From Rear Of Vehicle With Ignition Off and/or Electronic Controlled Air Suspension (ECAS) Compressor Cycles Too Frequently (Reprogram ECAS Control Module)
Models:2003 HUMMER H2
with Off Road Suspension Package (RPO ZM6)
<A href="#ss1-1205170">Condition
Some customers may comment on a Service Air Suspension message and/or a clicking noise from the rear of the vehicle when the vehicle is shut off and the key is removed from the ignition and/or the ECAS compressor cycles too frequently while the vehicle is running.
<A href="#ss2-1205170">Cause
ECAS control module calibration issues.
<A href="#ss3-1205170">Correction
For diagnosis and repair of the ECAS, follow the service procedure below.
  1. For diagnosis of Service Air Suspension DTC C0711, refer to DTC C0711 (SI Document ID #857738).
1998 Chev Z71
2007 Chev Trailblazer SS
