06-10-2011, 06:15 AM
I NEED HELP!!!!!
Im new here, im a strong believer in these forums. Im a do-it-yourself kind of guy. i am on all ford powerstroke diesel forums and if it wasnt for them my truck wouldnt be on the road
ok well my dad calls and says when the a/c is turned on the hummer (h2) blows cold out of the passenger side and hot air out of the driver side. so i hit up my good friend google and find out that it is a temperature control actuator for a door to direct the a/c. well i took the driver side actuator out and the gears didnt looked stripped out. i plugged it back in and turned the ac on and off and watched the gear move.
the gear that connects to the door starts in the middle and when you turn the air on it moves clockwise, turn it off and it moves back to the middle. but never turns back counter-clockwise past center. is this thing for sure bad or is there something else. thanks for your guys help.
2005 Ford Powerstroke Diesel 6.0 4x4
SCT Livewire custom tuned by matt @ Gearhead Performance, 4" turbo-back straight pipe(no cat, no muff) to a 6" tip, EGR delete, 6.4 banjo fuel bolts, Updated FPR kit, updated stc fitting, tinted, HID's, glowshift Pillar gauges(egt, fuel press, volts)
2004 Hummer H2 limited edition(Victory Red)
tv, strobe lights, lots of chrome, clear front turn signals with red LED's
24,000 MILES!!!!!!!!!!!!!!!
06-10-2011, 07:35 PM
Re: I NEED HELP!!!!!
You sure your looking at the right actuator. Turning the ac on and off will not change the left temp door position, that actuator will only move when the left temp is changed. The left temp door actuator is on the bottom of the hvac case. With the auto hvac system you could also have a sensor problem. Turn the auto setting off and try it
1998 Chev Z71
2007 Chev Trailblazer SS
06-11-2011, 03:50 AM
Ya. I did more research last night. I think the one I need to check is under the dash somewhere. Anyone got directions to get to it. I'm trying to figure this out without taking it to the stealership. All these fancy gadgets to run the ac
Thanks for your help
06-11-2011, 05:42 AM
1998 Chev Z71
06-11-2011, 05:44 AM
Well apparently the pics wont work. Its just to the right of the body tunnel on the bottom of the hvac case assembly. Remove the plastic panel and you will see it
1998 Chev Z71
06-11-2011, 06:31 PM
And this is passenger side. Right
06-11-2011, 10:05 PM
Bottom of the hvac case on passenger side is the drivers side temp door actuator
1998 Chev Z71
06-13-2011, 04:55 AM
ok i will look again but when i took that cover off the first time, i didnt see anything that looked like the actuator that i saw on the driver side, or is it not the same thing??
06-15-2011, 05:19 PM
is the actuator im looking for look the same as the one i found on the driver side?
