08-27-2011, 04:02 PM
bluestar reset?
does anyone know how to reset the bluestar besides pulling the battery cable? every once in a while the unit will lock up. the green light stays lite but the phone is not connected. thanks in advance.
also, has anyone upgraded from the older version bluestar to bluestar2010 and was there any added benefits?
scott j.
2008 h2 sut
2008 escalade
1969 charger
08-28-2011, 05:02 AM
Re: bluestar reset?
I had luck with that system...required frequent resets. I switched to the blue fusion by Scosche. It is much more reliable, much easier to install and streams music from my iPhone perfectly. My advice...google the blue fusion system.
08-30-2011, 04:56 AM
Re: bluestar reset?
Just ran into the same problem. Took my H2 into the shop and the killed my battery. (left key on) After recharging battery, the rear doors wouldn't lock and my bluestar wasn't working. I found that pulling the relays for the rear doors and reinstalling them fixed the problem. Faulty relays, need replacing. Hope it works for you.
2004 H2 Lux; Night vision, Helix Tower power 11, Volante CAI, Diablo Predator, Bluestar, 20" Weld Racing, 325/60 Terra Grapplers, Rancho 5000's + Steering Stabilizer, XTC Lightbar,Hella driving lights, Compustar Alarm + Remote start, 2 Elec. fans, Tru cool 4739, oem Rear camera,console vault
09-26-2011, 03:51 AM
Re: bluestar reset?
has anyone upgrade to the bluestar 2010 from the original bluestar with any added benefits?
scott j.
2008 h2 sut
2008 escalade
1969 charger
09-26-2011, 05:56 PM
Re: bluestar reset?
This may be a dumb question...but what the hell is 'bluestar?' Are you talking about OnStar?
UPDATE: Nevermind...I found it on Google.
CNTRY
DTOM
09-26-2011, 07:36 PM
Re: bluestar reset?
I would highly recommend blue fusion, never had any problems locking up or losing connection.
2008 Hummer H2 SUT
Greystone Metallic, Rancho 4" Lift RS9000XL, 20" XD Badlands Rims, 37x13.5x20 Toyo Open Country MT, AFE Cold Air Intake, BlueFusion Bluetooth, Flowmaster Dual Exhaust, Warn Winch 9.5Ti Multi, Gobi Rack, Baja Rack Duel Can Carrier
1995 Dodge Viper
Emerald Green, 18 & 19 5 spoke Rims, Autoform Hardtop
USAF (Retired)
09-27-2011, 03:42 AM
Re: bluestar reset?
delh2....i just read up on the blue fushion and it seems to have so many more options than the bluestar. the only question i have is do you have to use the microphone that comes with it? btw thanks for the info on the blue fusion.
scott j.
2008 h2 sut
2008 escalade
1969 charger
09-28-2011, 12:50 AM
Re: bluestar reset?
The blue fusion is quite easy to set-up, basic plug and play to your current XM mdoule, from there just run the microphone up the pillar to the head liner and place it close to you as possible. I put the mic next to my rearview mirror. Best part of it, is bluetooth streaming music from your iPhone!
2008 Hummer H2 SUT
1995 Dodge Viper
USAF (Retired)
09-28-2011, 01:17 AM
Re: bluestar reset?
where is the xm module located in the 08 h2?
scott j.
2008 h2 sut
2008 escalade
1969 charger
09-28-2011, 01:23 AM
Re: bluestar reset?
Just remove the glovebox and it's right there
2008 Hummer H2 SUT
1995 Dodge Viper
USAF (Retired)
